Grounding wire change?
  • Neverenough
    • Sep 2012
    • 907
    • Ft. Worth Texas
    • G
    I guess my boat was a late production boat. The ground is ran by itself like the bulletin.
    • toomuchuv
      • Mar 2013
      • 190
      • Canada
      • 2014 SAN 230
      So are you saying that the grounding issue causes noise to come through the AUX wire? Or are you saying that you had a different problem altogether? If rerouting the AUX cable and replacing it with a higher quality cable caused the noise to go away, then I would not have bothered with the ground cable relocation. It sounds like you did both.
      I was getting a CRAZY amount of noise coming through the AUX wire. Only noticed it after I did the ground wire change and still had noise.
      "I'm on a boat........"
      • scottparris99
        • Feb 2016
        • 20
        • louisville
        • 2014 SAN 230
        Originally posted by Guntersville230 View Post
        Thanks for the help everyone! Gonna work on this and update.
        Sent from my SM-G935V using PLANETNAUTIQUE mobile app
        Gunter....Did you ever get around to checking your wiring? I have 2014 230 i recently purchased with some annoying buzz while engine is running. Wondering if its a ground wiring issue. No noticeable buzz while engine is off.
