Grounding wire change?
  • pitts12driver
    • Oct 2009
    • 83
    • 2022 G23
    My brand new 230 has a stereo that sounds awful: engine whine, hiss, etc.
    Does anyone have the details on the service bulletin that relocates the engine ground and stereo ground? Would be greatly appreciated!
  • Tallredrider
    • Oct 2014
    • 1026
    • St. George, Utah
    I cannot comment on the service bulletin, but the best idea is to always ground all audio stuff to the precise same location if possible.
    • ffmedic74
      • 835
      • Lexington, KY
      x2 would like to hear the details as well!
      • trip33
        • Nov 2010
        • 248
        • Odessa, FL
        PM me your email and I will send it to you.
        • Guntersville230
          • Aug 2015
          • 419
          • Guntersville, AL
          • 2015 SAN 230
          Were you ever able to get this fixed?
          • ffmedic74
            • 835
            • Lexington, KY
            Tripp33.. Just sent you a pm
            • toomuchuv
              • Mar 2013
              • 190
              • Canada
              • 2014 SAN 230
              Thanks to Tripp as he sent me the bulletin as well. One thing to check lads is the AUX wire coming from the drivers side. I chased down this horrible buzz and once I removed that RCA from the HU, it went away. I ran a shorter, high quality RCA directly across over the front ballast tank instead of all the way around the front of the boat.
              You will find with the re-routing of the ground wire that there are wire ties along the proper route. You may have to epoxy on one or two but for the most part, they are there. Boggles my mind why Nautique would put them there but not route the ground in its proper spot.
              "I'm on a boat........"
              • Guntersville230
                • Aug 2015
                • 419
                • Guntersville, AL
                • 2015 SAN 230
                Do u still have info from tripp? I pm'd and have no response. Need help understanding how to reroute ground wire etc.
                Sent from my SM-G935V using PLANETNAUTIQUE mobile app
                • trip33
                  • Nov 2010
                  • 248
                  • Odessa, FL
                  Gunter - never got your PM? Try again.
                  • toomuchuv
                    • Mar 2013
                    • 190
                    • Canada
                    • 2014 SAN 230
                    Gunter- PM Sent
                    • Guntersville230
                      • Aug 2015
                      • 419
                      • Guntersville, AL
                      • 2015 SAN 230
                      Thanks for the help everyone! Gonna work on this and update.
                      • Tallredrider
                        • Oct 2014
                        • 1026
                        • St. George, Utah
                        So are you saying that the grounding issue causes noise to come through the AUX wire? Or are you saying that you had a different problem altogether? If rerouting the AUX cable and replacing it with a higher quality cable caused the noise to go away, then I would not have bothered with the ground cable relocation. It sounds like you did both.
                        • ffmedic74
                          • 835
                          • Lexington, KY
                          So will Nautique automatically fix this? Dealer claiming no clue per Nautique related to this issue.
                          • Neverenough
                            • Sep 2012
                            • 907
                            • Ft. Worth Texas
                            • G
                            Well i did a battery move and added one and still have the noise. Mind sending me the bulletin as well? Trip I sent you a PM. Thanks
                            • Guntersville230
                              • Aug 2015
                              • 419
                              • Guntersville, AL
                              • 2015 SAN 230
                              I sent you a PM but if it doesn't work let me know your email address and I'll get it to you as well if you are not able to get it from Trip
