Replacing Polk MM650 speakers
  • jkallen21
    • Jan 2013
    • 400
    • United States
    • 2006 Super Air 220
    I have a 2006 SANTE with 10 MM650 speakers:
    4x in Tower
    3x on starboard
    3x on port
    That's quite an investment in speakers alone - so I've decided to save some money and go with the DB651 which lots of people seem to love for the money. We don't ever max out the sound anyway and just generally like decent sound quality so I think we'll be happy. The old speakers are falling apart.
    Now comes the part where you're going to quickly realize I have little experience in audio. To be honest, I actually have a history in it, it's just that I haven't done any of this stuff since I was a kid and that would be around 1989 and I have not looked at it since so I do feel a bit lost.
    I have 2 stock amps - the Clarion APX480 and APX280. The 480 is a 4-channel and the 280 is a 2-channel.
    Some questions:
    How are 10 speakers powers by this considering there is also a 10" stock subwoofer?
    What does the wiring look like?
    The MM650 has 4 inputs on each speaker. There are two for the tweeter and two for the mid-range speaker itself. The DB651 seems to have just two inputs? Does it matter which of the existing 4 wires in the boat I use to power them?
    Thanks for the help.
  • 2009216v
    • Jun 2014
    • 88
    • Charlotte, NC
    • 2019 G23 2009 216V (Sold) 1997 Sport Nautique (Sold)
    All speakers, including sub, should be powered by your amps except your two bow speakers which are traditionally powered from the radio.
    • MLA
      • Dec 2009
      • 1312
      • Lake Wylie NC Area
      For tower speaker are wired to the 2 chnl with each chnl running at 2 ohm
      Four main cabin wired to 2 chnls of the 4 chnl, again, each chnls running at 2 ohm
      Sub is bridged on the remaining 2 chnls of the 4 chnl.
      Bow left on front chnls of the head-unit.
      A nice improvement is to install a mild mono amp for the sub, opening up 2 chnls for those bow speakers. This will then allow the fade function to be utilized better.
      • jkallen21
        • Jan 2013
        • 400
        • United States
        thanks MLA - very helpful.
        What about the DB651 only having a single pair of inputs vs the MMC650 having two pair (tweeter and midrange are separate). How would I go about this?
        • MLA
          • Dec 2009
          • 1312
          The MMC650 just has a detached cross-over, where as the DB has an integral cross-over. The mid and tweeter of the MMC are wired to their corresponding terminals on the cross-over, and in turn, the cross-over has a pair of terminals that are wired to the amp's chnls.
          • jkallen21
            • Jan 2013
            • 400
            • United States
            I see. So, inside each speaker cut-out today, there are 4 wires and it shouldn't matter which (matching) pair of those I use for the DB series?
            • MLA
              • Dec 2009
              • 1312
              Yes, it does matter and the correct pair has polarity. You need to eliminate the detached cross-over from the old speakers, and locate the 2 conductor speaker lead that runs to the amp.
              • jkallen21
                • Jan 2013
                • 400
                • United States
                I'm now understanding. I see the crossover on the DB now. I just need to take a closer look at the existing wires and find which one has a crossover attached to it and remove it or use the other pair. Thanks for your help.
                • jkallen21
                  • Jan 2013
                  • 400
                  • United States
                  I hooked up the left tower speakers today after eliminating the remote crossovers. The db651 sounded very "tinny" with no bass. Disabling the filter on the 280 amp improved that substantially. See the attached photo to see how the frequency is set. After all these years who knows what settings people might have changed. Let me know if you see anything that looks crazy.
                  • MLA
                    • Dec 2009
                    • 1312
                    If it was set to HP and is now set to OFF or FP, you have basically defeated that FREQ dial. I would suggest running them on HP at about 100Hz. A little polly-fill in the pod will help with a tinny sound.
                    • jkallen21
                      • Jan 2013
                      • 400
                      • United States
                      Thanks so much MLA. Your help was a HUGE HUGE timesaver. The boat sounds great right now - all speakers replaced. I will fine tune it later, but I can't complain right now.
