I am installing the Deafcon V's on my 2005 SAN and I have a question. Because the Deafcon V's are too wide to fit on the forward tower bar they need to be mounted on the rear tower bar. I wanted to run the wiring into the rear bar but it seems that the flat cross members are not open on the ends under the welds. Does anyone know if this is true?
If so then I have 2 options. 1) run the wiring to the front bar and just have the wires run to the speakers from there or 2) drill additional hole into the cross member at the other side of the weld and run it out of the front bar into the cross bar, out of the cross bar and into the rear bar.
By the way - to answer someones earlier question - yes you can hear the speakers quite well behind the boat. My system is the following
Polk Momo boat speakers running off the stock Clarion Amp 480M off channels 1 and 2, lefts are bridged and rights are bridged running at 2 ohm. Bow speakers running off head unit. Sub running off Polk C300.2 and another C300.2 running Deafcon V's on tower off rear channel output from head unit.
Any help or ideas would be appreciated.
