Ok , so today I was listening to music (VERY bass heavy music) and I had it up pretty loud and the sub was at +9 and everything sounded great when all of a sudden the sub just turns off. I thought oh **** I just blew it, I blew my 700 dollar sub...so I turned down the volume and it came back on and I was really confused at that point. At first I thought it was the battery so I hooked it up to the charger and repeated and the exact same thing happen. About 20 is the threshold...under that is great; above it is no sub. Any ideas as to what would cause this??? It has never done it on the water I was in the garage installing lights and listening to music. I have a Wetsounds XS-XXX if that helps.
Several potential causes including but not limited to are low voltage, thermal protection, or a combination of both. Sometimes an amplifier is doing the right thing by shutting down to protect itself.
Did you measure the supply voltage shortly after the sub amp shut down? Keep in mind that the static supply voltage is likely to sag much farther when there is a substantial current draw.
DavidEarmark Marine[URL="http://www.earmarkmarine.com"]
www.earmarkmarine.com[/URL]
No, but I will try that. I think voltage might have something to do with it because when we are on the water I play it at like 35 consistently and it never shuts down. I'm probably overreacting but it scared me to death.Originally posted by EarmarkMarine View PostSeveral potential causes including but not limited to are low voltage, thermal protection, or a combination of both. Sometimes an amplifier is doing the right thing by shutting down to protect itself.
David
audio... check (amp) ground 1st... then check (batt) ground 2nd... then check (block) ground 3rd!!! and when working with boats... grounds are always the issue... so check ALL the grounds after the 3rd check.....2001 Super Sport - GT40 1986 SN2001 - 351 1973 Cobalt - 188/888 2014 F150 Screw 3.5 twin turbo 2011 Expy 2002 F150 SCrew 2001 F150 SCrew 1973 K5 (toy) 1995 Burb 3/4 454 1991 K5 Blazer (DD/Toy) 1987 Honda Accord 1978 Ford F100 1981 Merc Capri 1991 Honda Civic 2002 Ninja 500R sold...
Perry- what amp and what impedance is it wired?2019 G23 450
2014 G23 550
2013 G23 450
2011 Malibu Wakesetter 247
2007 Yamaha AR210
