'97 Supersport - I have the dreaded engine noise through my tower speakers and I cannot for the life of me figure out why I am getting it!
Setup - Kenwood KMR-350U head unit, Kenwood KAC-728 300w RMS 2-channel amp running my Kicker KMT-6 tower speakers.
Backround - I had hooked everything up originally on a single battery with my old head unit - the original Clarion radio. Everything worked fine. I wanted to be able to use my Ipod so I bought the new Kenwood radio, and at the same time I installed this I also hooked up a second battery with a Perko switch. Re-wired everything up, and being a dumbass I am since I had power and ground the same color wires, I switched them and immediately blew both 20amp fuses on the amp. Fixed the wiring, put new fuses in, everything played fine in the driveway on batt power only. Hit the lake and...engine noise! I've tried EVERYTHING since that I can think of. Separated pwr and ground so they aren't running together up the side of the hull, went back to single battery to see if this would help, nothing. Changed ground location from block to engine cradle - no dice. The engine whine is the same. I'm wondering if it could be the head unit? The only 2 differences since it was fine on the old head unit are the new head unit, and maybe I did damage to the amp when I switched +/- and blew the fuses? Please help, I'm at my wits end and don't know where else to look without putting the old head unit back in and that is a total PITA.
