I am installing the Harmon Kardon drive plus play and I decided to install the box directly under the dash -- not on the bottom side but underneath the dash cover. There is currently another block box bolted on the right side of the steering wheel. What I am unsure of is all the wires running to the guages and things what wire could I use to connect the ACC to? I have removed the cig. ligther and will be using both that ground and positive to run the harmon system, could I use that positive to connect both the positive and ACC to from the harmon?
Do you think if I daisy chain the cig lighter in the wiring somewhere else that will cause any "noise" in the system, I just hate taking away functionality even though I rarely ever used that one by the driver seat.
Jason
Jason
