I installed a small amp and added 2 more polk speakers to my stock system in my 2006 -sv211. It sounds great in the driveway but i am picking up some egine noise when the boat is running. What is the most common cause for this? I used some RCA cables that i had laying around the garage. Would it help if i switched these out with shielded cable? Thanks for your help..
RE: Amplifier install
I would try some twisted pair style RCA's. I am running fosgate and they are reasonably priced. I have used them on three boat systems with good luck. No noise at all on any of them.2001 Super Air Nautique
Python Powered
100 Amp Alternator
Dual Batteries
Many upgrades coming...
I had issues with this with a small crappy amp. I got different cables, then a PAC in line noise filter, which helped, but cut frequencies. Finally I bought a new, nicer amp and the problem was gone. Probably the amp, I would say...
What kind of amp is it?Travis Fling
Choctaw Lake
What size amp and what size wire for the 12v + and 12v - ?
I believe you can get the noise you are describing from a bad ground.2006 SANTE 210 (Pending Sale)
2005 206 TE (Previous)
Make sure you're grounded to the battery right? Wasn't trying to infer your amp was sub par... Just something to check. You can pick up noise from engine components run with the speaker or RCA wire. If you have to cross mechanicals, then do so at a 90 degree angle.Travis Fling
Choctaw Lake
By engine noise I assume you're describing alternator whine that varies in pitch with the RPM. If so, this most commonly caused by a ground loop. But sometimes the noise can be induced by a bad rca shield or the wiring layout. And it is possible to have a bad amplifier. The general rule is:
*Ground the amplifier(s) directly to the battery.
*Run the amplifier(s) postive supply to the battery switch common lug.
*Ground the source unit to the largest amplifiers ground terminal or close to it as possible.
*Sometimes but rarely you have to pull the source unit's power and ground from the factory harness and move them to the same supply as the amplifier(s) in order to close the ground loop.
David
Earmark MarineEarmark Marine[URL="http://www.earmarkmarine.com"]
www.earmarkmarine.com[/URL]
audio systems are very sensitive to noise when components are operating off different voltage sources (power or ground). ie, your deck is running off the factory harness and your amp is connected to the battery. If you can get everything connected to the same power source with good wire to minimize voltage drop and if you run your audio links at least 6" from power wires (perferrably twisted audio links too). your noise issues should go away.
