Ok here's the scoop. Took boat to Local Dealer in OK. and had them install my Krypt 5-light bar(75 watt lights), on my 06 SAN TE w/the Flight Control Tower.
1. Wanted bar wired to Courtesy light switch.
2. Wanted all wires hidden.
This is what I ended up with. Also with no call to me before I picked it up.
1. Light bar wired to a Toggle switch in the driver side cubby. Per dealer the
courtesy switch couldn't handle the watts from light bar...
2. Wires were exposed all over. From light bar through tubing then out from where
it disconnects from base(to be able to fold down) then back in to base, out
close to the front driver side and through the fiberglass and to the toggle switch.
Yes i said through the fiberglass(they drilled a freakin hole and ran the wires
through it and left it that way). Again with no call to the boat owner!!!!!
Now my question is how is everyone else out there with a light bar have it wired. The dealer currently has the boat and is seeing what they can do.
My goal is to have to dealer pay to fix hole in boat and re-wire.
I will most-likley rewire myself because they do not give a crap about my 54k boat since they drilled a hole in it without telling me.
Suggestions??
Suggestions??
