I have a couple quick questions about my amp settings.
Currently installed:
Deck Alpine 7949
Amp #1 Alpine PDX 4.150
Tower Sp Boss B62 (MB Quart 6.5) on front channel
Sub don't remember
adding
Alpine PDX 4.100 for my internal speakers. These are nothing special at the moment, stock, and just trying to get them running for the moment. I will upgrade them at some point.
My two speaker questions are:
on my orig setup, should I have the filter set to HP for mid/tweeter only on the tower speakers or set to off for full range?
For the cockpit speakers on the new, second amp, same question. This will be independent off the rear channels, so I can kill the tower speakers with the fader at night, but still listen to music at a decent volume.
And a fuse question:
I have a large fuse from the Monster 4AWG wire kit I put in a few years ago at the battery. In order to hook up the second amp, I am planning on taking the original power cable from #1, running it to a distribution block (same for ground cable) Can I just leave the original fuse and run power straight from the dist block and rely on that original fuse, without adding any? I assume so, but please correct me if I am wrong on this point.
Lastly, is there any problem simply jumping the remote power on wire from Amp 1 to Amp 2 ?
thank for your help.
Deck Alpine 7949
Sub don't remember
adding
