Hello all!!!
1989 Ski Nautique 2001
I got the stereo done, with 260 watt amp pushing the tops, went with 4 Polk DB651's, two in the front gunnels, two in back that I built custom boxes for that fit under the gunnel walls. Put a downward firing 10" infinity sub up front pushed by a 520rms amp, mounted on the box. Elclipse cd3000 HU. Sounds great, except for two issues.
1. I'm picking up a lot of engine noise, which I assume is from a bad ground, but where to ground on a fiberglass boat? Right now it's grounded on the battery. Should I ground to the lift ring assembly under the bow? Put in a line noise filter? Any other ideas?
2. When the bass hits it cuts out pretty frequently, but then comes right back on. I turned it down which somewhat alleviated the problem, but that's not a good solution, as I have to turn the bass down... I assume the amp is drawing too much power, and is cutting out. Does that mean I need to put a capacitor in there to store some power, and alleviate the load it's pulling? If so, what type, and where would it go in the schematic? I believe in my truck I put my cap between the battery and amp, but just making sure, if that's the solution, that I've got it right.
Thanks in advance!!!
Travis
Travis
