Originally posted by WakeSlayer
indeed. and the locals don't think anything of it really. They give me crap for being nervous about it......the WakeSlayer
1968 Correct Craft Mustang
$300 plus two friends for a night out drinkin (not on a Nautique) = Two dead gators and one good cookout for the neighbors2006 SANTE 210 (Pending Sale)
2005 206 TE (Previous)
These things never happen when you power turn! Or I don't understand the concept of power turns.
To do this, you would kill the throttle really fast, then turn quickly enough at idle to hit your own 1st wake straight on.
If the water can't escape the bow fast enough, and it will not because in most cases it will get into the storage under the cushions and only slowly go backwards to the bilge then the next wake will be even worse.
So to avoid this, throttle down slowly, turn slow so you get hit by your wakes from the side and you'll be safe all the time even with huge wakes.
Another alternative is to throttle down and keep going straight in idle then turn in idle and maybe even go into reverse to go back in your own path. In the middle there will be almost no wakes at all.
Originally posted by peterkarlssonThese things never happen when you power turn! Or I don't understand the concept of power turns.
I come from I/O's where it seems stylish to power turn, which is REALLY bad for the gimbal bearings. I had to reeducate my wife, and myself (although I seem to have picked it up much faster) after watching "The Book". They have a specific lesson on driving, including the correct way to turn around so you don't screw up the lake.
Anyway, if you're surfing at 10 MPH, and you turn at that speed to pick up a fallen rider, you'll swamp the boat every time. If you're wakeboarding at 20 and you turn hard enough to nose into your own wake, you will also take water over the bow. I've done it. It's repeatable. It happens when you power turn.
Originally posted by peterkarlssonAnother alternative is to throttle down and keep going straight in idle then turn in idle and maybe even go into reverse to go back in your own path. In the middle there will be almost no wakes at all.
BTW, my dealer did ask if I'd owned a boat before and if I was comfortable with it's operation. They even explained the differences in backing up with an inboard vs I/O. Some do it right!2001 Ski Nautique / 2007 SV211 TE (gone but not forgotten)
Sorry for possibly confusing ya'll, where I come from power turns are when the boat is going at planing speeds which for most boats are above wakeboarding speeds.
