Get the Shred Ready Helmet! The HOG system makes it fit better than any helmet I have tried on! Not to tight, but not loose either...
H.O.G. Lock Retention System Upgrade
The Hand Of God (H.O.G.) Lock Retention System is standard on Shred Ready composite helmets and the Super Scrappy. It features two opposing micro adjusting ratchets on. Each ratchet tightens two mono-filiment lines that make for the prefect positive fit. The ratchets and anchors are attached to a coated PVC harness lamented and stitched to closed cell foam.
BTW, your physics or lack there of is wrong, a 10 # bag of lead falls at the same speed a 10 # bag of ping pong balls fall. The larger surface actually spreads the force over the larger surface area while the pole has a much more focused force, but both are the same as far as forces go. As far as decceleration goes I would much rather be hit in the head with a 10 # block of wood versus the 10# pole. The pole would probably go through my skull while the block would just dent it. I don't really get it in the head alot though and it appears as though you have more experiance in this subject than me.
Kids...put the phone down, text someone later and read a stinking math or physics book sometime...
