Originally posted by SuperSquirt
Do you guys have the same problem with the flight control tower???? Or are the directions correct for that one?'08 SAN 210 Team Black w/Patriot red top stripe-Tow Biminis over the tower-4 under water transom lights-hot/cold shower-crest carpet-full throttle steering wheel-extra 6 channel JL amp-Pro 80's-WS420-fiberglass sub enclosure-led'd vents-Chromax Letters-and Tinted windshield for now......
Tow Vehicle--05 GMC 2500 Crew Cab Short Bed 6.6L Duramax/Allison with a few mods
-GO DAWGS!-
I talked to my dealer he said the measurements are just a starting point for all towers.
Put all the clamps on but don't tighten all the way once its all installed then move them as needed to make it work.
My problem was trying to make it work with the given measurements.
Once I stopped using them it went fairly quick.
Use the measurments for a guide only, it will take tweaking after the bimini is on. The FCT will likely take some adjustments also. In response to trailering with it, It only takes about 2 min to fold it up from start to finish. I would not chance it.
