cover supports
I use 4" PVC pipe that I purchased at Lowe's...One 10 foot section cut into a 6' and 4' sections. You can buy rounded end caps to fit over the ends that touch the cover. Then I place the 6 footer over the ski pylon and the other supports my cover behind the engine box...all for under $25. It's strong enough ( 4" diameter) to withstand hot days and heavy Indiana thunderstorm winds. It's also extremely easy to put up in case of a quick rain shower. Make sure you but the rounded end caps as otherwise you may shred your cover. Nothing fancy, but I've tried alot of other more expensive methods and this works the best.
