Morse Control
  • dwsa
    • Sep 2005
    • 134
    Morse Control
    Does anyone have a procedure to set up a new Throttle cable on 2001 SN. My throttle seems to go way forward before operating the Throttle Body, yet It appears to have no slack in it.
  • TRBenj
    • May 2005
    • 1683
    • NWCT
    RE: Morse Control
    There should be a threaded adjustment on either end, no?
    1990 Ski Nautique
    NWCT
    • bchesley
      • Feb 2006
      • 1252
      • Tyler, Texas
      RE: Morse Control
      You can adjust the throw of the cable at the controler sided only. There are two holes on the throttle control that you can choose from. The right way to adjust it is to have the throttle in forward gear right when it engages the transmission and adjust the cable to slip in with no resistance. Then put your cotter pins in and your done. The tranny cable is supposed to slip in the brackets in nuetral with out any resistance. I hope that makes sense.
      Brad
      2001 Super Air Nautique
      Python Powered
      100 Amp Alternator
      Dual Batteries
      Many upgrades coming...
      • TRBenj
        • May 2005
        • 1683
        • NWCT
        Re: RE: Morse Control
        Since when? My cables have threaded adjustments on both ends.
        1990 Ski Nautique
        NWCT
        • bchesley
          • Feb 2006
          • 1252
          • Tyler, Texas
          That is not the throw. That is the length of the cable only. The throw is the arc that they travel in. I was wrong on the throttle having two holes. The tranny has two holes. Here is a illustration to show you what I mean. I replaced the old one in my 2001 and still have the installatoin instructions.
          Python Powered
          100 Amp Alternator
          Dual Batteries
          • dwsa
            • Sep 2005
            • 134
            Thanks, any chance you could psot the instructions. I think the throttle cable is spring loaded on a slider at the morse control end so wondered how to ajust correctly. I see the two holes for the tranny in your pic, which one should be used? Also my throttle body has two holes on the arm, so I'd like to know which ones to use as different throws on each.
            • bchesley
              • Feb 2006
              • 1252
              • Tyler, Texas
              Here is the MV2 control manual. It will be the same as your control.
              Python Powered
              100 Amp Alternator
              Dual Batteries
              • dwsa
                • Sep 2005
                • 134
                Fabulous, thnaks....
                Greg
