What oil should I use on a 94 SN with the PCM transmission??
RE: Transmission Oil
Conventional Dexron/Mercon ATF. I prefer Valvoline.
Do NOT use synthetic!1990 Ski Nautique
NWCT
Re: RE: Transmission Oil
Because its too slippery for wet clutch transmissions. PCM was seeing failures around 800-900 hrs when synthetic was used in the tranny. Stick with conventional.Originally posted by 93EuroWhy not?Originally posted by TRBenjConventional Dexron/Mercon ATF. I prefer Valvoline.
NWCT
