My 1992 SN started to overheat last weekend. The engine is a 351 Ford with a Holly carb, 245 hours. I checked the hoses, pump impeller (replaced last year), oil cooler and the t-stat. All were working fine. I checked the oil dipstick and the oil was at a normal level and clear. No water or foam thank goodness. When I felt the exaust manifold, I noticed that the left manifold was cool but the right manifold was very hot. I'm thinking that I have some kind of blockage on the right side of the engine.
I plan to back flush the engine by removing the engine drain plug (the one that I remove for winterizing) and flush with water from a garden hose on the boat dock. I hope this does the trick. The boat is on Lake Hartwell, about two hours away from home. Is there anything else I should examine or try?
Also, I know the water pump is working because when I checked the t-stat I had to replace the gasket. In doing this I ripped the new replacement gasket but installed it anyway. When I started the engine, a small stream of water flowed out the ripped gasket. Should I use gasket cement when I replace the next gasket? Do you apply gasket cement to both sides of the gasket?
Thanks.
Thanks.
