2003 SAN210 light question
How do you turn on the lights to all the engine instrument gauges? Do you have to have the engine running for them to be on? Also what are courtesy lights? I know I don’t have docking lights but not sure about courtesy lights. When I press this button the light on the button comes on but no other lights in the boat change.
Thanks A&B
Out of the owners manual:
Courtesy / Docking Lights
A quick press and release of this button turns on the courtesy lights,
and the indicator light for this button will illuminate. A press and
slight hold turns on the indicator light and the docking lights. Both
the courtesy and docking lights can be turned on at the same time,
but only if the courtesy lights are turned on first.
Navigation / Anchor Light
A quick press and release of this button turns on the navigation
lights, and the indicator light for this button will illuminate. A press
and slight hold will only turn on the anchor light and cause the
indicator light to flash. A press and release of the key turns off both
of the lights.
Thanks A&B
of the lights.
