eletronic keypad
  • whataboat
    • Jan 2005
    • 34
    eletronic keypad
    Hi everyone.
    I have just bought a 2001 year ski nautique and the electronic keypad is faulty. I am not able to enter the code to start as buttons 3 and 4 will not work.
    So does anyone have a method of replacing the pushbuttons with a normal key ignition ?
  • firedog33
    • Jul 2007
    • 1
    I also recently bought a 2001 Nautique and had a similar issue with the key pad. I had it in for some service and asked the dealer to change the code for me. He wasn't able to reprogram it because the #4 wouldn't work but somehow my start code was erased. This meant that the boat could be started with no code. I was messing around with it the other day and found that if I took a screwdriver and pressed hard on the number 4, the key would make contact and the green led would come on. This allowed me to enter the master code and set a new personal code. I don't know if this will work for you but it's worth a try.
    • xlair
      • 694
      • Wisconsin
      I have a carbon fiber keypad for your boat if it is indeed faulty. Let me know.
      2001 Pro Air Nautique
      • boatech
        • Aug 2006
        • 247
        replacing the keypad with a keyed ign. can be done. i have done a few of them. it is to involved to type on the forum. but talk to a boat mechanic its not crazy hard. takes a couple of hrs. where you from? the next time i do one i will try to make a manual of the procedure and i will send it to people that would like to do it.its been quit some time since i did one i cant remember all the wires and there colors off the top of my head. heck maybe ill make a kit and sell them and make millions!!!!
        • whataboat
          • Jan 2005
          • 34
          Thanks everyone
          Boattech, rack them grey cells for me, I can probably do the work if a set of instructions can be supplied.
          I am in the UK, and the dealer says it cant be done.
          • M3Fan
            • 1034
            That would be great! Please do!
            2000 Ski Nautique GT-40
            2016 SN 200 H5
            www.Fifteenoff.com
