Somehow the steel setup that protects the prop and rudder of my trailer has come un welded? There is a center beam that runs parallel to the boat (under the prop and rudder) that was welded to the back of the beam that runs under the rudder (perpendicular to boat - lowest back beam) has come un welded. I know I can unbolt all of this in a pinch to use the trailer, but I don't want to do this.
Has anyone else had this problem. Also, is there a way to order a new set up.
1996 Super sport, original Nautique trailer.
Thank you,
Geremy
Thank you,
Geremy
