I have a 2002 210 and I've noticed that when I turn right my indicated speed on PP drops much lower than my regular speedometer and PP tries to compensate and I end up going way too fast. When turning left everything is fine, both gauges read pretty close and the boat maintains speed properly. The paddle wheel is on the right side of the boat so I'm confused why it reads slower when I turn right. PP operates great in a straight line. Any ideas? Is this just a normal thing?
RE: Perfect Pass doesn
This is a random guess. Is you paddle wheel located on the left side of the boat? If it is, it might be in turbulent water when turning to the right, because the left side of the boat is higher, or the paddle wheel might get in turbulence from the fins on the bottom of the boat, or both might be happening.
This is a known problem. One of the ballast thru hull strainers is right in front of the pp paddle wheel and has been known to throw the PP off. Might be something else, but I'd definitely check into that.How about \"Chales\"?
RIP Nikolai (\'05 SANTE) 5/23/05 - 4/30/06
There was a service bulletin to change the thru-hull pickups from the scoop style to the flat style to get rid of this issue.Please do not PM me directly asking for advice on how to repair your boat. While I would love to help everyone, I simply do not have time to respond to all of the inquiries. Please post your questions on the forum, so that all of our members have a chance to answer.
