when we fired it up for the first time this year after winter storage (removed all drain plugs, water seperator, fogged, etc...) put everything back together and started it with the garden hose as we always do it ran fine, but the temp was up to 140 in a minute or 2 - we only ran it for a few minutes to make sure it started. Then we dropped it in the lake and noticed the temp was running between 200-220. we are getting normal water pressure and the motor was not any hotter than usual, if not cooler.
We ran it for about 1 hour and then back to the trailer when the temp light came on, although it was still reading 200-220.
the top of the water pump where it leads to the manifolds was cold to touch (running in 55-60 degree water)and as stated neither the motor nor the manifolds were that hot.
any thoughts on how to diagnose the problem?
