I need to get under there and check but i am figuring it is the heater core leaking which is creating water pooling under the dashboard. I tried searching, but does anyone remember of any threads that showed how to either bypass the core (i don't need the heater) or replace the core to eliminate this problem?
leaking under console
http://www.onlyinboards.com - over 1000 new and used inboard boats. Over 200 CC\'s on the site.
http://www.wakereviews.com - Submit 3 Reviews, get a free Vinyl wakeboarding sticker!Tags: None
If you don't need the heater pull the hoses off at the engine. unscrew the barbs and use plugs to seal them off. if you leave them in you can always replace the core later. If you do it at the engine it's usually easier than getting under the front.Nautiqueless in San Diego
