I recently bought a 2000 Pro Air, I just ski'd it for the first time. There is a small rooster tail right at about 15 off (otherwise the boat is great!!). Does anyone have any suggestions on the prop for the best wake?
Propeller Selection
I just went through propeller selection for my 93 Sport- Bill Weeks at Acme http://www.acmemarine.com is very very helpful. Give him your Hull ID, and tell him what you are looking to do- and they can suggest a match. If the prop does not perform the way you intend, return it and they will send you another--- until you dial in on the correct one.
RE: Propeller Selection
What prop do you have on the boat now? I *think* CC started using the Acme 422 around 2001, but am not sure the exact year.
On both the 90-96 Ski Nautique and TSC2 196 hulls, I havent noticed much of a difference between the Acme 422 and 470. The OJ Legend 4-blade was also comparable as far as wake characteristics go. The 470 was the hands down winner in regards to performance. I would expect it to work great on your boat as well.
From what Ive read, the Pro Air hull doesnt put out the best slalom wake. It has more of a deep-V design, so the effect a prop has on the wake could be quite different than what Ive seen. Putting a call into Bill Weeks at Acme is good advice either way.1990 Ski Nautique
NWCT
Re: RE: Propeller Selection
Good advice! I switched out the OJ on my '02 AN for the 422 and the biggest difference I noticed was in smoothness.Originally posted by TRBenjWhat prop do you have on the boat now? I *think* CC started using the Acme 422 around 2001, but am not sure the exact year.
From what Ive read, the Pro Air hull doesnt put out the best slalom wake. It has more of a deep-V design, so the effect a prop has on the wake could be quite different than what Ive seen. Putting a call into Bill Weeks at Acme is good advice either way.\'01 Sporty Air Nautique
RE: Re: RE: Propeller Selection
I put the 422 on KD7000's boat last night, will have a chance to run it Saturday.the WakeSlayer
1968 Correct Craft Mustang
