I want to change the plugs in my GT-40. What do I need? I dont have the manual or the boat nearby. I was going to pick them up at the store and head over to where the boat is stored and get them installed.
Need some spark plugs
Prior Boats:
1999 Ski Nautique GT-40
www.skiersofknoxville.orgTags: None
They are an autolite plug but I can't seem to find the number either. I could only point you in the direction of where to buy them online. You might be able to go to autozone and tell them it is for a HO 351 Engine. They might be able to cross reference it for you.
See if this helps. It says autolite 104. You can check it out for yourselves. Just go under the heading for PCM..
http://cpgcatalog.honeywell.com/auto...s/Inboards.pdf
Thanks for the help, I am going to send an email to Ken at White Lake, I am sure he will tell me for sure. I will post it if anywone else needs to know. Most all info is geared to the chevy engines now, and ford info is a little harder to come by it seems.
I am real hesitant about even getting her wet in ft. nasty. Our new house is halfway between Tellico and Ft. Loudon, so I think a lot of time we will be on Tellico. She will see some time on Loudon though, since my folks live on it.2005 Ski Nautique 206 SE, Acme 422, PP SG 8.0, ND Tower
Prior Boats:
nc, do you know where the polland creek ramp is off top side dr? we need about another foot of rain to stay off the 12" drop at the bottom of the ramp, but it has the best slope on lake nasty that i have found for dumping a ski boat.
chillhowee is right up 129 or 321/ foothills. the water is the 5th in the chain of alcoa owned lakes, so the water is cold enough to keep the weekend warriors away. if you want glass/butter, go to santeela in robinsville. you can see the bottom at 20'.red right return
I grew up about 4 miles from poland creek by road, My parents live at 624.5 near the cliffs. I have launced at Allisons most of the time, but not with this boat. This is actually the first time it has even been in TN. Chilhowee is a great lake, and if you really want cold go to the cold stream area where the trout hang out.....buuurrr its usually near the old ferry.
I havent been to Santeela, but have heard others talk about it. I am just glad to only drive 15 minutes instead of 45 to the lake. Thanks for the recomendation.....where do you usually boat at?
BTW if anyone else is intersted the plug for a gt-40 with fuel inj. is an autolite 764 gapped at .044. (thanks white lake.)2005 Ski Nautique 206 SE, Acme 422, PP SG 8.0, ND Tower
Prior Boats:
