perfect pass python installation ??
  • Miljack
    • Dec 2004
    • 1635
    • Charlotte, NC
    • '08 230 TE ZR6
    Hi guys,
    I'm well into projects and have now tackled the Perfect pass install and I have now discovered some items that I need to get clarification to finish the install;
    I need to build my own bracket for the servo motor mount. I have a rough idea, anybody have a pic of one?
    Throttle linkage? I've got a note from an owner, but not from anyone I've talked with at PP that I will need to "switch" my throttle control from pull to push to make the perfect pass work, anyone? Apparently this will require that the morse control be swithched from pull to push, but I'll then need to figure out how to get the throttle plates to open by another method. Again pics of an install would be great.
    Any other hidden gems on this?
    thanks,
    Jack
    2008 230 TE-ZR6
  • skijones
    • Mar 2005
    • 235
    • COLUMBUS OH
    • 1985 2001 1999 Snob
    Good luck. The best thing is once you get your throttle problem worked out, the rest is easy. Never worked on a python.
    When you run your wiring, leave a extra rope from the bilge to the helm. Running the fish tape is the hardest part.
    • WakeSlayer
      • Sep 2005
      • 2069
      • Silver Creek, MN
      • 1968 Mustang
      I have the PP on mine, you do need a different bracket. I will get a photo of mine for you tonight. I will ask a buddy about the throttle, never heard that before.
      the WakeSlayer
      1968 Correct Craft Mustang
      • WakeSlayer
        • Sep 2005
        • 2069
        • Silver Creek, MN
        • 1968 Mustang
        Here are two pics of an install on a 99 SAN. I have no idea about the throttle. Maybe that is a direct drive thing ? Measurements included. I had a weler buddy fashion the plate for me for a case of beer. Easy stuff.
        Photo and measurements courtesy of the Zman, another Python Powered Super Air owner.
        the WakeSlayer
        • Miljack
          • Dec 2004
          • 1635
          • Charlotte, NC
          • '08 230 TE ZR6
          Wake slayer,
          THANK YOU! This helps a ton. I luv this place... :grin:
          2008 230 TE-ZR6
          • WakeSlayer
            • Sep 2005
            • 2069
            • Silver Creek, MN
            • 1968 Mustang
            no problem, dude. Always glad to help a fellow Club 502 Member.
            the WakeSlayer
