Hi All,
I have installed new kodiak disk brakes on my single axle ramlin trailer and the brake pad on the fixed side of the caliper isn't flush with the rotor? its on angle such that at the top its in contact but slightly angles away as you go inward to the center of the rotor.
Will this true itself up after a few hard stops? I can't see anyway of adjusting them to correct it? I took it for a slow spin around the block with a bunch of stops to try and properly seat them - but they are still off?
Any help would be appreciated.
