Excalibur 330 ECM Diagnostic Port
  • Rusty Axle
    • Nov 2023
    • 112
    • IN
    • 2006 Air Nautique 226 Team Edition
    Hey gang, I need some help identifying the ECM diagnostic port on my 2006 Nautique 226 with Excalibur 330 engine.
    I ordered a Rinda Techmate Pro so that I would be able to read any codes the engine ECM might set. Here’s pics of the unit and plug:
Name:	Yechmate Pro Unit.jpg
ID:	692812 Click image for larger version
Name:	Techmate Pro Plug.jpg
    After staring at the wiring harness for a while, the only plug that looks like it could be a diagnostic port is the narrow 6-pin one next to the red circuit breaker button that has “405051-A” on the cap.
Name:	Fuse Holder.jpg
    When I remove the cap I see that it has what appear to be 3 yellow fuses with no values showing. Possibly these are jumpers and not fuses? If this is the diagnostic port, then I have the wrong Rinda unit, based on plug shape.
Name:	Engine Pic 13.jpg
    Here’s more pics of the engine and wiring harness. It’s a V drive, so when I use “front” and “rear”, I’m using hull orientation and not engine orientation.
    Starboard front:
Name:	Engine Pic 12.jpg
    Starboard Rear:
Name:	Engine Pic 11.jpg
    Port Front:
Name:	Engine Pic 1.jpg
    Port Rear:
Name:	Engine Pic 5.jpg
    Here's a pic of the front:
Name:	Engine Pic 6.jpg
    My Techmate Pro is an expensive paperweight at the moment, so any help resolving this would be greatly appreciated.
  • JayG80
    • Dec 2006
    • 262
    • Santa Fe, TX
    • 2007 Ski Nautique 2002 Ski Nautique 1999 Moomba Outback
    My 2007 Excalibur 330 is drive by wire with econtrols ecm. The diagnostic port is near the thermostat. Top of engine on the oil fill cap side.. Mine has 2 ports coming out of a wire loom with a sticker that says Engine diagnostics.
    • JayG80
      • Dec 2006
      • 262
      • Santa Fe, TX
      Click image for larger version  Name:	IMG_0445_Original.jpg Views:	0 Size:	238.0 KB ID:	692832Here is the port with adapter 94026 Diacom attached
      • JayG80
        • Dec 2006
        • 262
        • Santa Fe, TX
        Picture #2 - Without adapter plugged in. My ECM and wiring may be different. I use the box shaped port (upper one with the gray cover) for reading the DiaCom information and had to buy a 2nd adapter to the flat port (lower flat 6 pin, black cover with green pins) when I downloaded a new ECM calibration file after replacing throttle potentiometer.
        Click image for larger version  Name:	diacom port 2.jpg Views:	0 Size:	281.5 KB ID:	692835
        • jpwhit
          • Aug 2016
          • 692
          • Cary, NC
          I’m not as familiar with Techmate as full Diacom, but I assume this is the same. Did you order the correct adapter to match up to your boat? I always order the Diacom setup with the full adapter set because it’s only universally useful with all the adapters.
          • JayG80
            • Dec 2006
            • 262
            • Santa Fe, TX
            my 2007 uses 94026, looks like 2006 uses 94005
            • Rusty Axle
              • Nov 2023
              • 112
              • IN
              Thanks guys for the helpful responses.
              The good news is that my Rinda unit has the 94005 connector. Now if I can just find the port....
              Here's a pic of the same area on my engine. There are two ribbed plastic-shrouded wires running beneath the black-booted thermostat connector, which is just under the black rubber water hose. One with a blue stripe and one all black. They appear to continue to the underside of the engine. I gently tried to pull them to see if a connector might come up however they appear to be secure. There is nothing underneath the spark arrestor.
Name:	Plug Area 3.jpg
              Later today I'll take the panels out of the starboard compartment and see if the ECM port is in a less accessible area near the pulleys/belts.
              • JayG80
                • Dec 2006
                • 262
                • Santa Fe, TX
                https://www.planetnautique.com/vb5/f...330-vortec-5-7
                This guy posted about the location on his 2003 and says "It's called a data link connector it's on the starboard side of the top of motor near the back and it is plugged into another connector. Just unplug a few until you see this one pictured below."
                • Rusty Axle
                  • Nov 2023
                  • 112
                  • IN
                  Folks, I believe that we have a winner! Thank you JayG80 for the guidance. I found this plug coiled up and zip-tied on the starboard rear of the engine. I was accustomed to the diagnostics ports on automobiles, which are open fittings for the diagnostics unit. This plug, having male and female connectors with continuous wiring, cause me to rule it out. After disconnecting the two, the male slipped into the adapter on my Rinda Techmate Pro unit, and the Rinda unit activated immediately upon being plugged in. Unfortunately I'm getting a "No ECM detected". I cycled the ignition off and back on (without the motor running) and got the same message. So a conversation with Rinda support is in the works.
Name:	ECM Port Plug.jpg
                  I noticed the same style plug connected directly to the black box, so for due diligence disconnected it and plugged it into the Rinda unit. Nothing happened whatsoever, the Rinda unit stayed asleep no matter what I did. However I noticed a long and narrow 'mystery plug" that I could find no connection for.
                  This pic shows the plug disconnected from the box and the mysterious plug coming off the wiring.
Name:	ECM Mystery Plug 2.jpg
                  This pic shows the plug re-inserted into the box along with the connection end of the 'mystery' plug.
Name:	ECM Mystery Plug 3.jpg
                  The good is that I'm learning more about my boat. Thanks again everyone for the help.
                  • SNGuy123
                    • Jun 2022
                    • 6
                    • WA
                    • 1996 SN & 2006 SANTE 220
                    RA, sounds and looks like we have the same engine. I have a 06' SANTE 220 w/the 330. Every picture you have posted looks exactly like mine. I also have the two looms going down by the thermostat and could not find plugs on them either, but did not look under the engine yet, just gave them a gentle tug.
                    I did not buy the Techmate Pro unit, and opt'd for the software with laptop. I am ALSO trying to find this port and actively looking every night when I get home for the little 30-45 min. I have available outside of kids and the family. As you noted, this Rinda tech and the boat that does not want to work are an expensive paper weight sitting in my driveway.
                    I appreciate the photo's and updates, please keep them coming and let us know if you find it. I will do the same.
                    Funny thing is, I just posted last night about that single plug that goes to nothing...appears it was meant to be empty if we both are seeing it. Been searching high and low for wiring diagrams and other posts and could not find anything that says anything about that little pigtail that goes nowhere. I also noticed in the first pic above in post #9, that you also have what appears to be a black wire clipped off at the plug end where wires come in. Mine has the same clipped wire, also a weird thing we are both seeing.
                    • JayG80
                      • Dec 2006
                      • 262
                      • Santa Fe, TX
                      Ed at Rinda Technologies is great at tech support. Two tips before you call:
                      1) Be sure to update the software.
                      2) Take a photo of the wires and the port. Write down what color wire goes into each connector spot, they should have numbers A-K. I had that No ECM issue on my first reading and had to unpin two wires from the boat CAN diagnostic connector and swap their positions.
                      I bought DiaCom because I thought it might offer more data so I am not versed in TechMate.
                      https://www.planetnautique.com/Corre...MEFIManual.pdf
                      • JayG80
                        • Dec 2006
                        • 262
                        • Santa Fe, TX
                        SN Guy, I updated my DiaCom software from the website even though I bought it new. https://www.rinda.com/updatemenu.htm
                        I watched their video tutorials too. https://www.rinda.com/training/training.htm
                        • Rusty Axle
                          • Nov 2023
                          • 112
                          • IN
                          I spoke with Rinda support, who responded immediately after the receptionist forwarded my call.
                          Their guidance:
                          Step 1
                          Check for 12 volts at diagnostic port
                          The Rinda adapter uses 4 pins – the ones in the opposite corners are power and ground. If the label is missing on diagnostic port, that's no issue as reversed leads will simply show negative voltage.
                          The other 2 pins should show only a couple volts when touching the positive lead to the plug connector and the negative probe to any ground.
                          Step 2
                          If there are voltage issues, trace the wires into the harness to ensure there is no break in the wire.
                          Step 3
                          If voltage present and still “No ECM Found”, connect the Rinda to another engine to test the unit.
                          The male plug shows alpha letters on the exterior. Facing the connectors on the open male plug, the characters across the top are F G H J K with E D C B A across the bottom.
                          Click image for larger version  Name:	ECM PLUG 7.jpg Views:	0 Size:	143.2 KB ID:	692903 Click image for larger version  Name:	ECM PLUG 10.jpg Views:	0 Size:	165.9 KB ID:	692904
                          Click image for larger version  Name:	ECM PLUG 11.jpg Views:	0 Size:	207.8 KB ID:	692905
                          F = Orange
                          G = Orange/Black
                          H = empty
                          J = empty
                          K = snipped black wire
                          E = Tan/White
                          D = empty
                          C = Pink/Black
                          B = Gray/White
                          A = Black/Yellow
                          Here’s a pic of the wires in the loom leading to the male plug.
                          Click image for larger version  Name:	ECM PLUG 6.jpg Views:	0 Size:	139.2 KB ID:	692906
                          With the ignition on, testing across the A & F connectors shows 12 V.
                          Click image for larger version  Name:	ECM PLUG 1.jpg Views:	0 Size:	200.0 KB ID:	692907
                          Testing at the B connector shows .01 volt, so something is there.
                          Click image for larger version  Name:	ECM PLUG 2.jpg Views:	0 Size:	306.7 KB ID:	692908
                          The remaining connectors show no voltage. SNGuy, if you have a voltage meter handy it would be interesting to see if your plug shows the same values.
                          To check the wiring for continuity I’ll have to pull some things off the top of the motor, as the loom runs underneath the flat plate that holds the throttle linkage.
                          The female plug has only two wires, a red and a black that run to the harness at the back of the engine compartment. The rest of the connectors are empty.
                          Click image for larger version  Name:	ECM PLUG 5.jpg Views:	0 Size:	163.0 KB ID:	692909 Click image for larger version  Name:	ECM PLUG 3.jpg Views:	0 Size:	155.7 KB ID:	692910
                          Given that it’s a gorgeous day for boating in Syracuse Indiana, I’m deferring further effort to another day.
                          The boat runs fine and has no issues. I simply want to know that I can read codes if I ever need to.
                          • SNGuy123
                            • Jun 2022
                            • 6
                            • WA
                            Hey Rusty, I can confirm that the plug in your post #13 is the correct plug for the diagnostic port. I have the Diacom software, not the handheld scanner, but I was able to plug into that port you have shown in post #13 and connect to the ECM successfully. I no longer have a $700 paper weight!
                            I believe the Key ignition must be in the on position (so gauges lite up), engine off for the system to connect. Engine can be on, but at a minimum, ignition needs to be on so power is running to the ECM.
                            Hopefully you get it working. Appreciate the photos and updates, I'm sure this will help someone out in the future.
