As is epidemic, I have ballast pressure sensor problems on my '19 GS20. Anyone know the location of these suckers? Any helpful hints on replacement?
Tags: None
Probably very similar to the G23. It's going to be all the way in the back, way down low. On the G, there's an opening in the fiberglass about the size of a tennis ball. The fill hose goes through it. You'll also see the wire going through that same hole. The sensor should be there.
-Charles
