This is one of those "that could never happen, but it did" moments.
We were having a fuel interruption issue on a 2005 Excalibur 330 in a Ski Nautique at Silver Cove Marine last week, and found an unusual cause. Someone in the past had changed the fuel pickup in the tank, but LEFT THE BROKEN PICKUP TUBE inside the tank! The new pickup's cut-out at the end where the screen is located is JUST the right size for the old tube to fit perfectly and cut off the fuel flow completely when it is sucked up against the opening. This fits perfectly with the running concern -- it would run great for five minutes or so, then sputter. Once turned off (and the suction releases), the boat would start up and run fine for a few minutes, until it all happened again. We pulled the tank, cleaned it out, and removed the old tube, and now it is fine. So, the lesson here is to always remove the broken fuel pickup tube from the tank before installing the new one!!
