Hi,
A few weeks ago i've hit a piece of wood when cruising around 3800 rpm, I immediately put the boat in neutral, but now the transmission makes a weird noise when i put the boat in the forward gear. (low rpm) when the rpm's go a little bit higher the noise stops.
In neutral and reverse is everything ok, no weird noisses.
The propeller has 3 folded blades out of 4. can this be the reason of te noise ? trans fluid is still clear.
thank you for the advice!
Gunther
https://youtube.com/shorts/DFl2zWcTz1w?feature=share
Gunther
