I have a 2005 SV211. When running in the driveway, with a garden hose inline, I get a fair amount of water coming out around the shaft as well as through the exhaust flap. When I did the winterization last year, It seemed as though most of the anti-freeze came out through that shaft area and less through the exhaust flap. Is this normal, and is there a way to block off the flow there, so I can get more into the engine?
A dripless packing system will do that. It is normal.
Did you drain your engine block and exhaust risers before adding anti-freeze? The flow typically goes to the shaft seal first, and then to the block. If the block and exhaust were empty, it will take several gallons to fill them before you'll see it come out through the exhaust.Please do not PM me directly asking for advice on how to repair your boat. While I would love to help everyone, I simply do not have time to respond to all of the inquiries. Please post your questions on the forum, so that all of our members have a chance to answer.
