Skidim.com now has new Holley 4160 Carburetors. https://skidim.com/holley-4160-carbu...-350-ford-351/
As of June 2025 PCM and HOLLEY were unable to supply the long standing Marine version of this carburetor.
We are supplying this via a marine conversion where the stock 4160 is changed to meet USCG standards by changing the bowls and sealing the external float adjustments- these are new units and due to the fact Holley only supplies the aluminum shiny finish (rather then the marine gold finish) we have primed and painted these to help with external corrosion in harsher marine environments.
Each unit is tested and serialized by the convertor (a company with over 70 years of carburetor experience here in the USA)
Original product description below:
This New 600 CFM V4 Barrel Holley Carb 4160 (RA052003) fits GM 350 Ford PCM, Indmar 351, Standard and H.O. Engines. Be sure to order a spacer gasket for underneath the Holley 4160 Carburetor (RM0054B).
NOTE it is important to change the fuel filter when installing a new carburetor.
New performer Holley 4160 Marine Carburetor that we sell is OEM. Carburetion is far from obsolete! The 4160 Holley Carburetor has been specifically calibrated to meet the demands of today’s higher horsepower ski boat engines. Upgrade your Holley Carb 4160 today!
Order your spacer gasket for underneath the carb, Item RM0054B.
