Sorry guys if this has been posted before and hopefully simple but just cant find.
I have a poor temp reading on analogue dash gauge. Very low but moves just a little at end of pass as temp rises in engine. Its sounds like there are 2 senders in this model??
2008, 343 excal in 196 ( Not gateway version). I can easily see the two wire sender near the thermostat but from reading this is just for ECM?? Apparently single wire sensor for dash gauge somewhere on block?? Can not find it. Do some of these engines just use the one sensor and some how the two wire sensor feeds the dash gauge also?? Obviously was working recently and then went low. Sure the engine temp is fine. Maybe its the dash gauge?? How can i fault find?? Thank you.
