Fuel pickup tube
  • SteveDoc
    • Nov 2012
    • 35
    • The Pond and Sacramento Delta
    • Redwood city ca
    • 2002 Ski Nautique 196
    Fuel pickup tube
    I have a 2002 Nautique trying to remove the fuel pickup tube from the poly tank and it does not want to budge. I have cranked pretty hard on the elbow could go harder but don’t want to break anything. Any suggestions would be helpful. The fuel system works fine I am just doing some maintenance changing sender unit fuel lines and want to change the anti siphon valve and pickup tube. Thanks for the help.
    Steve
  • SilentSeven
    • Feb 2014
    • 2241
    • Bellevue WA
    • 2004 Nautique 206
    A picture would be helpful.
    Bellevue WA
    • chris196
      • Mar 2007
      • 225
      Any luck on this. I'm trying to remove the fuel pickup from a 98 SN and it will not come out fully. After I loosen it, I can pull it almost all the way out, then it just won't come out the last bit. It's like there is something on the end of the line bigger than the hole.
