2020 G23 Spark Plug Cylinder 1 how to remove.
  • PTFlyer
    • Oct 2025
    • 2
    • Fairfax Station, Va
    • 2020 G23
    I have a 2020 G23 and was attempting to Fog the engine. I could not get the spark plug boot off of cylinder #1 due to the raw water system being in the way. Does anyone have tips on how to access this spark plug?
  • DocPhil
    • Jan 2016
    • 480
    • Midwest
    • 2016 G23; yamaha superjet
    Did you try by hand only or do you have a boot puller?
    • PTFlyer
      • Oct 2025
      • 2
      • 2020 G23
      I only attempted by hand. Boot puller will be the next step, any suggestion on a boot puller? The angle to the plug is very tight
      • DocPhil
        • Jan 2016
        • 480
        • Midwest
        When I changed the plugs on my 2016 G23, I bought a few different types of boot pullers on Amazon. I ended up needing 2-3 different ones to get the job done. I just kept the ones I used and returned the ones I didn't. These were the ones I kept.
        https://www.amazon.com/dp/B019Z09JHU...d_asin_title_3
        https://www.amazon.com/dp/B0CCNF2DG1...d_asin_title_6
        This one was a good idea but absolute garbage so I returned it. Avoid
        https://www.amazon.com/dp/B0954H1PLL...d_asin_title_4
