2021 GS22 Ballast Sensor Question
  • obiwon
    • Jul 2004
    • 7
    When I turn my boat on, my port ballast tank typically shows 42% full when it should be empty. When seeing this, I usually "empty" it in the water where it remains at 0% until I turn the boat off again (powered down). However, when I power the boat up again it's back at 42%. The last time it happened I "emptied" it out of the water on the trailer but no water came out even though the tank fill percentage would decrease. Any thoughts on the problem? TIA
  • GMLIII
    • May 2013
    • 2821
    obiwon No doubt your ballast sensor is toast. If your boat is still under warranty, I would get your dealer to replace all 3 of them because those will fail as well. The design of these ballast sensors is just terrible, and the failure rate is horrendous. Very common issue with these boats.
    • obiwon
      • Jul 2004
      • 7
      Thank you! I will reach out to them.
