2008 SAN230 Low Voltage noitification
  • DBattt
    • Dec 2006
    • 55
    My 2008 Low Voltage warning came on and then after that could not start the boat. The Batteries were strong enough to finish pumping out the ballast but the engine would not turn over. Seems like it required that i reset the fuses, not sure but coing a reset on all the fuses helped.
    Is this due to bad batteries or is the altenator bad???
  • swatguy
    • 1668
    • Midwest/ Northern IL
    • 2008 SANTE 210
    Definitely have the batteries load tested. Start there for sure.
