PCM 409 Start Sequence
  • behindpropellers
    • Apr 2008
    • 116
    • Chippewa Lake, Oh.
    Looking for technical information on how the start sequence is initiated. Our 2013 200 with a PCM engine has a hanging starter issue. When the starter button is depressed the starter will stay engaged. Pressing the stop button will turn it off. I have installed a work-around by adding a second momentary switch in series with the transmission gear switch.
    I have checked:
    Relay above the engine.
    Connections between the circular connector and the relay.
    The yellow/Red wire is staying hot after the engine has started.
    Tim
