Hi all.
I have a 2005 Nautique 226. This spring, the port fill ballast pump will run for 5-10 seconds then blow its fuse.
I know where the centre tank and bilge pump are located, but I can't see the port and starboard pumps.
Anyone know where those two specific pumps are located so I can replace it? Is it under the engine like the owners manual shows? If so, how do you access them?
