SN200 2014 Normal engine temperature
  • BertClijsters
    • Jun 2025
    • 15
    • Bree ( Limburg Belgium )
    • 2014 Ski Nautique 200
    Hello All,
    Since this year I am owning a Ski Nautique 200 with an PCM Excalabur 343 engine. I have some questions about the normal running temperature when skiing.
    When I am pulling a skier 55 Kph ( 34 Mph ) my running temp is about 164-165 degrees. Then wen I drop of the skieer the temperature rises to max 170 degrees and goes down after a few seconds at idle to 161 degrees. When the boat is at idle it stays at 161 degrees.
    Is this normal behaviour for a nautique ? My previous MC Prostar 190 boat didnt go that high in temperature.
    I allready placed a new impeller and a new thermostat. I also placed complete new water strainer. Tightened all the clamps from the water hoses, to be sure there are now air leaks.
    Can somebody share his experiences with same boat ?
  • Rednucleus
    • Jul 2022
    • 250
    • WA
    • Club Boat 2014 Ski Nautique 200
    Sounds perfect to me!
    • BertClijsters
      • Jun 2025
      • 15
      Your temperature is also al litte bit above 160 degree, I read somewhere that this should be spot on 160 under all loads
      I don't want to overheat my engine, then you have a lot of ****.
      • Interjon
        • Dec 2019
        • 159
        • Alabama
        • 2003 196 2019 SN200
        Don’t worry about it. Your boat is functioning normally. Every ski boat will gain a few degrees on the back side of a ski run through the course. Totally normal.
        • XBIGPUN66
          • Oct 2012
          • 477
          • Lake Mendota
          • WI
          We usually see about 162 underway. It will surge to 163 164 when you come down to idle. I usually just throttle up slightly to high idle for about 45 sec or so until it bumps back down to 162 or lower
          Ian S
          2014 SANTE Reef Blue/ Black metal flake. NSS. Pro balllast. Boatmate trailer
          2004 SANTE Masters Blue. 4000 lb ballast, 2013 graphics (prev). Ramlin trailer
          2009 Moomba Outback Red(prev). Boatmate trailer
