2007 SV211 Dead fuel gauge
  • SMOBLEY21
    • May 2025
    • 3
    • Martinez ga
    • 2007 SV211
    I saw you commenting on some other posts and I figured I would message directly… I have a fuel gauge that went kind of erratic when I fueled up and would only read half full and almost empty now does nothing all within a few hours. It also does not light up the only gauge that doesn’t light up. I tested my sender and it is reading ~75 ohms resistance after spending a half day on the lake.. but gauge reads nothing even after I jumped the two wires going to the gauge. Any help would be great. I’m reading a lot of probably the gauge or connections on the gateway.. gauge is not available and I’m not sure where the gateway is located. I also have the belly and port gauges that do not work either however I haven’t tried to trouble shoot those yet. I am a first time boat owner. Just insure of next step. Thanks in advanced
  • MN Ryan
    • Aug 2020
    • 1398
    • Maple Grove, MN
    • 2007 SV-211 TE
    Gateway is behind the kick panel under the driver's helm.
