Hi Everyone,
I have a new to me 2020 G23 with 190hrs.
When I did the walk through at the dealer the power/actuated tower (not telescoping) did go down and up, but then after trailering it home (roughly 450 miles; tower in up position) I went to put the tower down to place it into storage and the tower would not drop. I looked at any power connections I could find to check connections (mostly wiring near the batteries), but nothing looked obviously disconnected. After this, however, I went to lower it again and it dropped. However, it is now stuck in the down position as it would not go back up and I'm unsure what fix I might have temporized to make this happen.
Observations:
-Tower is unlocked prior to attempting to lower, nothing seems to be physically obstructing it
-Up and down button lights illuminate when the power button is pressed
-No tower motor noises can be heard while trying to raise or lower the tower (pressing the buttons)
-Batteries in boat are both brand new.
-Tower circuit breaker is not popped.
-I've done a power cycle of boat (turned off/on main breaker, with 15-30 sec rest in off) gives me the same outcome (no noise/movement).
-Does not seem like there is a location for tower circuit faults on the Linc screen.
Anyone have any troubles with these towers? Any suggestions? Perhaps someone might have a wiring diagram so I can follow some connections. I've read in a different thread re same topic that running the boat fixed this? I haven't had a chance to take it on the water yet, so perhaps. But I'm little reluctant to try with a downed tower haha.
Thanks in advance for anyone's time!
Observations:
