1999 Ski Nautique 196 With GT40 Won't Start
  • mebrannan
    • Dec 2024
    • 1
    • Gainesville, GA
    • Thanks for all you do
    Hello All,
    Boat won’t start. Troubleshooting & Conclusion. Would love you advice / opinions / comments.
    Background:
    • Ran boat last week on water, ran great. I’ve owned boat for 13 years, put 700 hours on it (total 1100), boat has always been great. Runs great.
    • 1999 ski Nautique 196 with Ford GT40 fuel injected engine.
    • Did end of year oil and oil filer change and transmission fluid change. Ran in driveway on fake a lake just fine.
    • Did FCC fuel filter change. The fuel filter in the high pressure silver fuel can that feeds fuel injectors.
    • Went to winterize by sucking antifreeze in the boat and engine would not start. Cranks and cranks, but does not fire. This NEVER happens on this boat.
    Trouble Shooting Steps:
    • To me feels like fuel issue, especially give that my last act was to change fuel filter in FCC. Note, I’ve changed the fuel filter annually for 13 years, so not a new process.
    • Battery is new this year
    • Tested pressure at fuel rail via Schrader valve. 0 pressure.
    • Low pressure pump is working fine. I’ve removed the silver can to look at the high pressure fuel pump multiple times to see if I’ve messed anything up in there (wires, tube, filter placement, etc.). And each time I look into the silver FCC it’s full of fuel. Note, I empty fuel out in-between looks. So I know the low pressure fuel pump is working. Plus, I can hear it and feel it as usual when you turn the ignition key 1/4 turn clockwise
    • Checked all breakers on panel on back of engine. I have 60, 15, and 12.5. All seem to be fine. All electric accessories on the boat appear to be working fine (radio, heater, shower, etc.).
    • Checked the two relays back there. Removed from boat, and bench tested them. Applied 12 volts to close switch. When relay is not powered, impedance between switch poles is infinite (open). When switch is powered (closed) impedance is less than 1 ohm.
    • Voltages at the relay connection sockets appears normal. 12 volts on the right pins when ignition key is turned 1/4 turn to the right. This tells me the computer is trying to close relays at the right time during the ignition sequence
    • Tried to measure voltage at both pumps when key is turned. Disconnected the connector to the low pressure pump (which is clearly working). Put meter across connector. Turned key, voltage goes up to 12, then drop to zero. Pretty sure this is a feature in that the computer senses no current flow and then therefore shuts off voltage. Replaced connector, turned key, and low pressure pump cycles as expected.
    • Repeated above step for high pressure pump. Disconnected electrical connecter, connected meter across connector, turned key, saw voltage jump to 12, then go to zero. Again, I think this is a feature b/c computer senses no current flow and therefore kills voltage to pump.
    Conclusions:
    • Ignition sequence of events appears to be working. Key turn - power flows to pumps.
    • Low flow fuel pump working fine
    • Power is getting through breakers and relays to the fuel pumps
    • High pressure FCC silver can is filling with fuel, and yet no pressure at the fuel rail.
    • Conclusion - high pressure fuel pump has died after 25 years. I don’t love the fact that it died after I messed with changing the filter in the silver can, so still makes me wonder, but I believe this is the part I need to replace. The high pressure fuel pump is the culprit.
    Thanks, Mike
  • Silver Cove Marine
    • Jul 2024
    • 6
    • Lake Norman, NC
    • Mooresville, NC
    • Many Nautiques
    First, just FYI, you do not have a 196. You have a 1999 Ski Nautique. The 196 moniker didn’t start until 2003.
    When you change the fuel filter in the FCC, you must prime the fuel system. Sometimes this can take 10 – 20 turns of the key (off to on, not start), where you hear the fuel pump run.
    If you did that and it still isn’t starting, check the safety lanyard. The condition you describe is exactly what would happen if that was disconnected.
    If you think the relays may be bad, just replace them. They are cheap and do fail often.
    One last thing. This is a long shot, but I had a GT-40 do this once a couple of months ago. There is a possibility that it is flooded. Use the lockout button on the throttle arm to allow you to advance the throttle to full throttle, and crank it over for a few seconds like that. Be ready to immediately pull the throttle back if it starts.
    Silver Cove Marine specializes in the high-end restoration and sales of inboard watersports boats.
    With decades of experience, our team is among the best in the business.​
    • Jonny Quest
      • Aug 2014
      • 464
      No fuel pressure at the rail could be a high-pressure fuel pump that is failing and/or a fuel pressure regulator that is bad. Not too terribly expensive or difficult to fix.
      JQ
      • JayG80
        • Dec 2006
        • 262
        • Santa Fe, TX
        • 2007 Ski Nautique 2002 Ski Nautique 1999 Moomba Outback
        While you are messing around in the FCC, make sure the 2 internal wires are firmly attached to the pump..
        Also inspect the wire harness on exterior top of the FCC canister, if it is surrounded by sealant then look at this retrofit kit for safety. https://nautiqueparts.com/repair-kit...trol-cell-fcc/
        If you replace the high pressure pump, swap out the short hose internal to FCC. The hose will crack over time and result in reduced fuel pressure. https://nautiqueparts.com/internal-fuel-hose-for-fcc/
