Good evening.
I'm currently in the process of purchasing a 2006 SV 211.
I noticed that I only have storage space up to floor level under the bench seats.
After that there is empty space up to the hull, which sounds very hollow when you tap it.
Does anyone know if the space is filled with foam?
I currently have a SAN 210 built in 2001 and it has foam between the floor and the hull on the left and right sides. A few years back I drilled into it to see if it was dry.
Thank you
Greetings
Alex
Thank you
Greetings
Alex
