2017 GS22 Port Ballast had a fault and I purchased the new OEM pump. I can see the ballast pump and the 4 screws/bolts that hold it in. Does anyone have any idea how to better access it? Or is there a way to removed the larger portion of the cover that surrounds the drain plug access cover since the pump is sort of below that? Would appreciate any tips!
