2006 Nautique 226 LE - Where Is The 'Gateway' Located?
This topic has been answered.
  • Rusty Axle
    • Nov 2023
    • 99
    • IN
    • 2006 Air Nautique 226 Team Edition
    I need to check some connections on the gateway that drives the gauges. It does not appear to be located in the starboard rear storage locker nor in the engine locker. There is a circuit breaker box only in the rear locker.
    It is not on the back side of the footboard beneath the dash. There is only what appears to be a fuse box.
    I will appreciate any guidance on this.
  • Answer selected by NautiqueJeff at 07-06-2024, 04:51 PM.
    Rusty Axle
    • Nov 2023
    • 99
    • IN
    The gateway box is mounted on the underside of the dash.
    If it was a snake it would have bit me.
    Thanks for the help.
    • briantin
      • Aug 2023
      • 34
      • Owensboro, Ky
      • 2006 SANTE
      On my 2006 220 it is located behind a breaker panel under the dash at the drivers feet. I have to remove that breaker panel lie on my back up under the dash and look up.
      • Rusty Axle
        • Nov 2023
        • 99
        • IN
        • jlatrace3
          • Aug 2024
          • 2
          • Birmingham AL
          • 2004 Air Nautique 226
          Question regarding installation of a gauge conversion kit and my 2004 226 TE:
          Since the gateway is under the drivers side it seems that changing out the old failing gauges and bypassing the gateway would be plug and play (after changing the gauges in the pod and following the install instructions) because you don’t need to run the cable to the rear of the boat.
          Am I mistaken? Also, advice about doing so on a 2004 226 TE is greatly appreciated.
