95 GT40 feels sluggish out of the hole.
  • powderjay
    • Sep 2018
    • 17
    • Brighton MI
    • Malibu 23LSV
    Runs good otherwise just a little extra time getting up to speed.. thoughts?
  • Jonny Quest
    • Aug 2014
    • 464
    I would look at MAP sensor, Injectors and ignition timing.
    JQ
    • Kyfooter
      • Jul 2020
      • 29
      • KY and TX
      • 1997 Ski Nautique, 2013 MasterCraft 197, 1992 Barefoot Sanger
      Jonny - Where is the MAP sensor? Any chance you might have a part number?
      • Jonny Quest
        • Aug 2014
        • 464
        MAP = Manifold Absolute Pressure sensor. Tells the ECM (computer) the pressure / vacuum of the air coming into the engine. That, in turn, provides data for the ECM to tell the injectors how much fuel to apply. if the injectors and fuel system are having problems, then the engine feels sluggish and won’t reach max potential. Look at fuel injectors, fuel pressure regulator and FCC or fuel control cell (filter and high pressure pump) and low pressure fuel pump. If the ignition timing is good, then many problems can be traced back to the fuel delivery mentioned above.
        Your engine is 30 years old. Parts wear out. I’ll look around for my list of part numbers. You don’t have to use PCM parts, as Ford used most all these parts in other applications. RockAuto.com has most of what you need (FCC excluded). You should be able to swap out IAC, MAP, TPS, injectors, regulator, low pressure pump and fuel filter for under $500.
        JQ
