I've changed impellers on several different SNs, but this one is new to me. The raw water pump housing is actually at or below the floor. See the below photos.
How do I access to change the impeller? I believe I loosen the belt tensioner and then remove the one hinge bolt (on which the tensioner rotates). At that point the whole assembly comes loose and I can then access the four bolts on the back? Please confirm. Once I have this done, I will take photos of the whole process and put on here.
Jeff, this is the SN you sold me; so, it is highly likely you already did this and know.
Thanks as always, everyone.
